Labview and Modbus
Hello
I want to communicate my modbus compatible devices with labview..
And therefore i need guidance about the library and software uses for that operation.
How can i communicate my devices with Labview.
Please tell me ....
"SB02"
Message 1 of 8
(4,721 Views)
On website they are writing that: In the LabVIEW Project window, right-click My Computer and select New»I/O Server, but i have no that option..
Now what to do ?
"SB02"
Message 2 of 8
(4,710 Views)
On what website? A search on NI's site says to use either DSC (an add-on module you must purchase) or the Modbus library.
Message 3 of 8
(4,697 Views)
i found from NI website :"https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0QgCAI&l=en-US"
i have already intalled Visa4.5.
then what should do ?
"SB02"
Message 4 of 8
(4,576 Views)
That white paper is using the DSC toolkit, which is an add-on.  I suggest using the NI Modbus library that Dennis linked to earlier.
Message 5 of 8
(4,569 Views)
i understand that but..
My poject is:
I have home made RS-485(2-wire) compatible modbus protocol supported relay card.
Its address is (41302) and slave ID is (11).
this whole word (41302) has its bitwise relay..
and i want to operate it from labview as individual switch for each relay.
This is my target..
So please help me for this..
If i'm sucssed in this project then i can use Labview in my another project..
"SB02"
Message 6 of 8
(4,515 Views)
So, what happens when you use the functions from the modbus library? What functions are you using? What settings? What errors do you get?
Since this is a homegrown modbus device, I would strongly suggest trying some commercial modbus program to help isolate any problems to the hardware or software.
Message 7 of 8
(4,497 Views)
I have already tested my relay card with Modscan software and it's alright.
I'm able to on/off relay from modscan.
And now I want to start working with Labview, I have done only internal program program but not work with external devices through COM port.
So I don't know how to start.
So please help me step wise..
How to start from beginning..
I know how modbus protocol works..
"SB02"
Message 8 of 8
(4,474 Views)
