Labview and HP GPIB Card
Hello
Have anyone succeded to use the HP82341C GPIB-card and HP VISA-drivers
together with the LabView. If so how to do? According to NI it will only
give problems if I try.
Regards Gert
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,012 Views)
On Mon, 25 Oct 1999 11:45:09 GMT, g_johansen@my-deja.com wrote:
>Hello
I succeeded using a HP GPIB-card with HP-VISA and Labview, but I am
not sure if it was the 82341C. As I remember, you must do the
following:
If you have installed HP-VISA and LabView and it doesn't work, try
installing HP-VISA again. After this you must start the Solution
wizards/instrument wizard to prepare HP-VISA to run with LabView, as
far as I remeber you will be asked if you want to use HP-VISA with
LabView. If this doesn't help, try to communicate with the instruments
by using the tools, which are installed with HP-VISA to c
heck out, if
the GPIB card is set up correctly, perhaps you have choosen the wrong
IRQ.
I hope this will help you.
(3,012 Views)
