Labview and Autocad
this example is for autocad 2007.  Check the activex refnum in the diagram.
cosmin
Message 21 of 31
(3,275 Views)
Although i am using autocad 2007. I checked the refnumbut i amstill getting the same error. What do i do?
Message 22 of 31
(3,264 Views)
run in highlight execution. tell me from wich node the error occur.
cosmin
Message 23 of 31
(3,263 Views)
The error is from the "Automation open" icon and it says that the class is not registered. It looks like it is not even accepting the refnum.
Message 24 of 31
(3,255 Views)
Recreate de refnum with AutoCAD type library-> AcadApplication
Message 25 of 31
(3,238 Views)
Can anyone help with info on interfacing Labview and Revit Architecture. It is possible with C sharp and VB but i prefer to use LV. I am having problems calling my Revit file in LV.
(FYI- Revit is an Autodesk product like autocad)
demmy
Message 26 of 31
(3,212 Views)
Hi, Your information about Autodesk are from 2010. Now, I am interesting for 3D CAD Autodesk Inventor 2013 machine prototyping
There are WEB information Mechatronics Series Part II: Conceptual Design Visualisation - Introduction to CosmosMotion ad LAB VIEW. There is about SolidWorks Office Premium 2007. This is 5 year old software so I presumed any progress with possibility to use another 3D CAD, too.
http://zone.ni.com/devzone/cda/tut/p/id/6025
http://www.ni.com/white-paper/6183/en
Where can I get detailed new information about machine prototyping with Autodesk Inventor 2013?
Do you know if tere are any plans to do that in future e.g. with Autodesk Inventor version 2014?
Mike J.
Message 27 of 31
(2,807 Views)
I spent a good deal of time looking for resources that could help you but the links you posted were the most up-to-date that I could find. I found in some other forum posts that it may help for you to check out some AutoCAD forums and see if there is any pertinent information there.
Blake C.
Blake C.
www.ni.com/support
Message 28 of 31
(2,766 Views)
I recently posted an example project showing how to interact from LV to AutoCAD using .NET
https://decibel.ni.com/content/docs/DOC-38857
Jannis
Message 29 of 31
(2,640 Views)
hello all
how can i send data to writ  it to unigraphics or Autocad using LV program
i have some points data XYZ and i need to send it to auto cad or unigraphics to draw it automaticlly
Message 30 of 31
(2,606 Views)
