Labview Web Server Memory Usage
Hi Guys
I discovered the exact same problem - NI recognizes this as a bug and as usually there is no horizon for when it is fixed.. fortunately another bright mind on this very forum came up with a solution that works.. minimizing the window programmatically will not work, as it does not trigger the same chain of events in windows - look at the thread I posted earlier here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=474974&requireLogin=False
I've now redone the library to run on LV8.6 as well, and made a very simple VI to empty the memory of the process with "VIname.exe" - it works like a charm - i flush the memory every 10 minutes, but a more elegant solution would be to check the current memory consumption of the program and then set a trigger level - but I have not worked out a solution for this..yet.
Message 11 of 12
(1,036 Views)
this is an application that implements some process monitoring and memory deallocation.
cosmin
Message 12 of 12
(1,026 Views)
