Labview Vs. Excel help
I have made an excel sheet using excel
can someone guide me into changing the excel worksheet labeled "chat1, 2,3, etc." to be rename to anything i want?
i used the activeX method
Krispiekream
Message 1 of 11
(4,749 Views)
An excel sheet (Chart, Worksheet, etc) object has read/write "Name" property which is the text on the sheet tab.  The following Excel VB code lists the sheet names in a workbook to the Immediate window:
Sub ListSheetTabNames()
    Dim i As Integer
    For i = 1 To Sheets.Count
        Debug.Print Sheets(i).Name
    Next i
End Sub
If you have a reference to the chart you have created, you should be able to change the Name property for the chart.
Message 2 of 11
(4,723 Views)
i dont know how to use VB codes in labview.
do you have any picture?
any diagram?
thanks
Krispiekream
Message 3 of 11
(4,703 Views)
thank you, but i have figured out with your help!
Message Edited by krispiekream on 11-14-2007 03:42 PM
Message Edited by krispiekream on 11-14-2007 03:49 PM
Krispiekream
Message 4 of 11
(4,695 Views)
I have attached a VI that uses the "Name" property of a worksheet object to change the tab name.  It is a bit horrible to look at but this is automation in LabVIEW - not always pretty!
The VI does the following:
1.  Open an instance of the Excel Application object and makes it visible (for some reason, if you use automation to create an instance of Excel to work with, it will be created with the visible property set to false - go figure.
2.  Add a new workbook to the Workbooks collection.
3.  Add a new worksheet to the new workbook's Worksheets collection.
4.  Use the worksheets "Name" property to retrieve and display the created worksheet's name
5.  Uses the "Name" property to rename the sheet tab.
6.  Uses the "Name" property to retrieve and show the new name.
If you are doing a lot of automation of Excel, I would get a good book on programming Excel that describes the automation interface.  John Walkenbach has written several good ones.  (http://j-walk.com/ss/)
-cb
Message 5 of 11
(4,680 Views)
i forgot to mention that i am using labview 8.0.
can you save for previous version?
thank you!
Krispiekream
Message 6 of 11
(4,675 Views)
Message 7 of 11
(4,670 Views)
NICE!!!
I looks great.
Its very similiar to what I used, but yeah, it is very useful!
Krispiekream
Message 8 of 11
(4,661 Views)
Hi everyone..
Can someone please save this for LV7.1?
Thanx very much guys..
Message 9 of 11
(4,338 Views)
Hi I_Pant,
attached is a picture of it.
Mike
Message 10 of 11
(4,308 Views)
