Labview VI is getting closed by Windows error
I have an labview program that I am working on. When running the VI I get this message "LavVIEW 7.1 Development System has encountered a problem and needs to close. We are sorry for the inconvenience." It gives you the option to send the error report on not, and then is closes Labview. How do I go about troubleshooting this problem? How do I collect the error log?  My program had seemed to function OK for several days of debugging and then this error started to happen regularly. It seems to be happening in a subVI that is reading an INI file.
Thanks for any help,
Dan F.
(2,777 Views)
I believe that if you send the error report, the screen that come up says something liek "thank you for submitting your report" and then there will be a "Details" button that gives you the text of the log file.
Chris Bakker
SET Americas
CEO
(2,754 Views)
did u check the event viewer?.....it gives us some information about the module having problems........
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(2,733 Views)
