03-04-2019 03:25 PM
I took over a Labview project and made some changes.The file name appeared in development mode is "Thermal Test 3.6 [Thermal Test vbeta V3.74.vi]". This is new to me. Why does the VI have two file names on top ? In addition, when I deploy the VI , the top of exe file always shows "Thermal Test 3.6" even if I changed the application file name as "Thermal Test 3.74". How can I change the title on top of the deployed exe to the right version (3.74 instead of 3.6) ? Please find attached picture for details.
ffl3883
Solved! Go to Solution.
03-04-2019 03:39 PM
You can set the Window title by going to File >> VI Properties (or ctr+i), then Window Appearance category.
