Labview System Exec VI
i have just successfully created a labview application program that calls another labview VI with the use of a system Exec. As usual, the sys Exec calls another exe by a file path. Would I have a problem when transferring this application I have made to another computer or will the file path in my program change automatically after transferring. Thank you
(1,666 Views)
Accepted by topic author Obed41
If you hard code a file path and name in your program.
That exact file path and name MUST exist on any machine you plan on running it.
That's why hard coding things like this is usually discouraged.
=== Engineer Ambiguously ===
(1,624 Views)
