Labview Shared Variable configuration
I need some help with my labview shared variable configuration.
In my setup I have a PC running with my lvlib on it.  This PC is NOT my development PC.  The application deploys the lvlib.  My program is I can't see those variables on my PXI RT Controller.  I have the shared variable engine installed on the PC.  But I can NOT add my realtime system to it.  When I enter in the IP address it just doesn't add it or give me an error msg or anything.  Anyone have any idea what's going on?
(3,913 Views)
No one has any idea why I can't add my RT PXI controller to my list in variable manager?
(3,894 Views)
Hi Zorro,
I need a little clarification of the particular situation.
1) You said this is not your development machine.  What software do you have on your development machine?  Did you make an installer, and install it onto the host?
2)  Which PXI RT controller and chassis do you use?
3)  Do you have Measurement and Automation Explorer on your host?  And can you see your controller there?  Can you ping the device?
Brian K.
(3,882 Views)
