Labview: Send Data periodically and sequentially from ini file over com port
I want 2 things from my vi:
> First, read the data from .ini file
> Second, send the data to com port periodically and sequentially.
For example, in the ini file i have the data as
data 1 - $GPRMC,123519,A,4807.038,N,01131.000,E,022.4,084.4,230394,003.1,W*6A
data 2 - $GPRMC,143724,A,2226.575,S,11955.982,E,0.000000,45.0,111217,005.0,E*64
data 3 - .
data 4 - .
data 5 - .
..... so on
Vi needs to send the data1 then data2 then data 3 every 1 second interval to the com port.
Any suggestions/examples are highly appreciated.
Aniket
(2,824 Views)
Hi aniketjha,
1. Read this "ini" file as an array of lines
2. send those lines to the COM port in a loop
What exactly do you have problems with?
Did you start to create a VI?
(2,801 Views)
Hi
(2,788 Views)
Accepted by topic author aniketjha
Hi aniketjha,
(2,776 Views)
Thanks Gerd for the heads up, for me i was also looking for how to retain the GPS coordinates as mentioned in ini file.
Now, i am able to simulate it successfully.
Regards
Aniket
(2,749 Views)
