Labview Runtime Engine installation problem with OSX
I tried to load the LabView Runtime 7.0 Engine for Mac OSX Says it's installing in my Applications folder and seems to be downloading the files. However, nothing is in the Application folder (and nowhere else on the HD). If I try to run a vi, it can't locate the program. If I try to reinstall, it says the files are already there. Can someone please help me with this problem?
(2,663 Views)
I suspect the runtime is in a folder called National Instruments. You
might just do a Finder Search for that folder or for LabVIEW and see
what shows up. If you logged out and back in again between installation
and execution, it could be a permission problem.
Greg McKaskle
(2,663 Views)
