Labview RT Reed Solomon VI
Hi!
I 'm currently developing a labview RT application  using reed solomon coder-decoder.
I would like to know why the decoder Vi works on I8 array with only one significant bit? I openned the Vi and I can't see where working on an I8 array is an advantage!!!
has anybody an idea?
Thanks a lot!
(4,783 Views)
What is this VI, is it a VI from a instrument driver?
If yes, you should contact the developer of this driver to have the answer.
(4,594 Views)
Reed-Solomon coder-decoder is not part of LabVIEW RT.
I heard NI Signal Express (modulation toolkit) has this function.
George Zou
George Zou
(4,588 Views)
Reed Solomon vi are from modulation toolkit. 😉
(4,570 Views)
Hi Jules,
they are only using values of 0 and 1 in those I8-bitstream array... So they mimic a boolean array...
Probably easier to do all the math stuff inside when you don't need to convert numbers to booleans and back all the time!
(4,561 Views)
