Labview PID, resolution of Output
Hello!
I'm using a the standard PID block and using a output range of 0-1. This means that the PID controller can output a minimum of 0 and a max of 1! My question: when the controller is active it only outputs fixed numbers, so this will be 0.1,0.2,0.3 and so on to 1! How do I change this "resolution" so it can output 0.12, 0.16 and so on?? If I pick a range of say 0-5 it outputs 1,2,3,4,5, not 1.5 or 2.3 and so on. Hope you understand my question.
Thanks!
/Andy
(2,761 Views)
No. The PID vi outputs a double precision floating number, so what you write is not true. For example, if the PID algorithm results in a 0.345673876 value as output, this value will indeed appear on the output wire.
Since you did not attach your VI, I can only guess: the numeric indicator what you use is set to show only the first digit after the decimal point? Try to change the format in the settings of the numeric indicator...
(2,743 Views)
