Labview-OperatorInterface and Login-Button
i´m running the example Labview-Operator-Interface with some modifications.
When starting the UI it starts also TestStand and executes automatically the Login-procedure. Then the SequenceFileLoad of the Teststand-model executes a sequence-call "in a new execution" which is running all the time in a loop.
What i see now, is, that the Logon-Button on the UI becomes grey and disabled and i cant press the button.
So my question is: How can i execute a login with User/Password while the "parallel"-seqeunce is running?
(Later i want to use Login-type to give access to several functions on the UI.)
Thx for our help
Attached a screenshot of the Login-button in the blockdiagramm
(3,081 Views)
post linked to
http://forums.ni.com/ni/board/message?board.id=330&message.id=16417
(3,033 Views)
