Labview Object questions
Developing a modular data acquisition system the would use multiple types of daq hardware. Some of the hardware is NI (cDaq & PXI) and some of it is LabJack (T7). My goal is to design a universal daq program which would allow the use of hardware abstraction to use any type of hardware but I am having trouble implementing my design. The issue I am having is trouble creating an class hierarchy that uses different initialization routines and communication protocol (Ni DAQmx task vs LabJack handle) for the hardware. Does anyone have design patter to solve this issue? Am I going about this is the wrong way?
John
(1,789 Views)
John,
This is a problem that I suspect every veteran LabVIEW programmer has struggled with at some point in time, myself included.
Each design I've looked at has trade offs; however, the closest I've come to a true HAL implementation used a JSON file to configure each instrument. A single JSON file included instrument initialization parameters and pointed to the LVClass name. So, startup would go something like this:
  1. JSON file is read from disk, fed into the parent class method "Start HAL".
  2. Parent class would read initial parameters like logging path, log rate, etc. Then the parent would read an array of instrument engines to spawn. In this design, each engine was asynchronous. Each instrument entry into the JSON contained the following information:
    1. LVClass to load, following factory pattern.
    2. Instrument initialization parameters. Each instrument class would override a parent method called "Read JSON Parameters" that knew how to interpret its own initialization information from the JSON file. For example, a VISA instrument would have a different set of parameters than a TCP/IP instrument, but the child class knew how to interpret/read the different entries into the JSON.
    3. Array of channels that would go into an I/O FIFO. The FIFO was used for IPC from the HAL to the remainder of the program. Each entry into the channel array also contained:
      1. calibration information
      2. channel type information
      3. LVClass name for on-the-fly signal processing (also factory pattern) if needed.
        1. Signal processing parameters also interpreted by child class based on parent method.
In the end, this design worked fairly well... but the resulting configuration JSON became unwieldly to set up as well as drawbacks in the timing/synchronization side of things. It also didn't allow for any type of closed-loop control for each engine, though the FIFO probably could have been abused to allow for some changes.
Now that I've given you my best answer, here's my best advice.
Give up and find a COTS solution from one of the companies out there. Doing a HAL right that is long-term supportable and sustainable is a much, much bigger effort than I realized with my first attempt. Or second attempt. Or third. There are a huge number of little "gotcha's". If you're anything like me it'll become an all-consuming pet project moving from tester to tester until it is such a mess that I barely understand it and any other engineer coming in has zero hope of supporting my code at a future date.
(1,743 Views)
My company has done this and we have been pretty successful with some things that are easy to make universal (power supplies and such) but other things are a lot harder.  Making DAQs universal is one of those things that was in the "much harder" category.
In the end we ended up with one class that was "Simple DAQ" essentially, that basically didn't do anything that involved precise timing, triggering, or waveforms.  It could read or write Boolean values for the DIO channels, and read and write analog values to the analog in and out channels, but only a single value at a time per channel, and always untriggered.  We implemented this for DAQmx devices as well as a few other non-NI devices.
For anything that needed to do a complex DAQ task, the HAL basically was a way to wrap a DAQmx reference in a LabVIEW class wire, but when it came time to do the fancy stuff we'd just pull out the DAQmx reference and use it directly.  For NI hardware the DAQmx wire is already a HAL for the most part, and for non-NI hardware the effort it would take to allow full use of all NI's DAQmx features but also support other devices transparently was a massive undertaking that we judged would not be worth the effort.
(1,721 Views)
Though technically possible, it requires substantial effort, maintenance, and scalability, which are the challenges.
It is easier to fix on to one vendor than try to invest in hardware abstraction.
Santhosh
Soliton Technologies
(1,719 Views)
Back (a decade ago) when NI was doing "traveling Road Shows", I attended a one-day event in Rochester that was an early introduction to LVOOP that was all about building a HAL using LVOOP.  As I remember, it looked reasonably sensible.  I suspect one could find this presentation with a suitable Web search -- it might even have been an NI Week Presentation ...
(1,704 Views)
As of now, I landed at the same place.  I have no more to add than what you already posted.
I would invest some time to look into FlexLogger.  You can create a plugin to handle the LabJack channels and put it all in a single project.  I have only briefly played with FlexLogger (a free "lite" version was just released), but it looks promising.
(1,667 Views)
