Labview .NET API Database Constructor Node can not associate DBC in veristand
Hallo everyone,
I want to modify the system definition file of Veristand through the VeriStand .NET API of Labview. I refer to the tutorial in this link and add a CAN port in Veristand through the API.
https://www.ni.com/docs/en-US/bundle/veristand-net-api-reference/page/vsnetapis/lv_sysdef_creating.h...
My VI screenshot is as follows:
The port can be added successfully but I received the following error in Veristand, showing that there is no such database:
But I am sure that there is already such a database in Veristand:
It seems that this node does not work. The version I use is Labview 2023 Q1 and veristand 2023 Q4.
Do you have any ideas about this problem?
(1,004 Views)
You need to first add the database to the target.
Reference: System Definition Examples — niveristand-python 3.1.0 documentation
https://tmesystems.net/
(956 Views)
