Labview Multisim API toolkit, How to control multisim
I would like to control either a switch or a power source in Multisim via Labview by using the API toolkit.
However, whatever I try, it doesn't work.
Does anyone have an example of how to do it?
Note that I don't want to use the LabVIEW-Multisim Co-simulation feature since it's limited to 24 input/output.
Thanks!
Judith
(6,210 Views)
Hello Judith,
Possibly this information will be helpful for your, it is regarding co simulation between LabVIEW and Multisim:
Introduction to Digital and Analog Co-simulation Between NI LabVIEW and NI Multisim
http://www.ni.com/white-paper/13663/en/
Using LabVIEW and Multisim: SPICE Netlist Simulation from LabVIEW
http://www.ni.com/tutorial/5933/en/
Have a good one.
LuisG
(6,156 Views)
Hi Luis,
Thanks for your feedback. However, we had already looked into those white paper and they do not cover exactly what we want to do.
For the first one you posted, http://www.ni.com/white-paper/13663/en/ , it's not a good solution for our project since it's limited to 24 input or output. Also, it would be impossible for us to divide our multisim file so we can have more than one multisim bloc to have more than 24 input/output.
On the second one, http://www.ni.com/tutorial/5933/en/ , I dont realy understand with that solution how to control a swith or a power source on Multisim via Labview. Do you have a concrete example? The one in attatchmenet does not have that function.
Judith
(6,147 Views)
Here: C:\Users\Public\Documents\National Instruments\Circuit Design Suite 14.0\samples\LabVIEW Multisim API Toolkit you will find the examples of the API. Also I've found the following links that may help you.
Automate Circuits Analyses with the NI LabVIEW Multisim API Toolkit
https://forums.ni.com/t5/Example-Code/Automate-Circuits-Analyses-with-the-NI-LabVIEW-Multisim-API/ta...
(6,117 Views)
I don't see any example in
or https://forums.ni.com/t5/Example-Code/Automate-Circuits-Analyses-with-the-NI-LabVIEW-Multisim-API/ta...
on how to set an input to multisim via labview.
Is there an easy way to control a DC voltage source via labview?
(6,044 Views)
I did a co simulation with LabVIEW to control a V source, take a look at the files attached, I think that if you play with it will be the best to understand the feature.
Luis G.
(6,021 Views)
