Labview LINX increment value when digital read is true
How to increment and decrement value when sensor digital read is true ?
(1,822 Views)
With such a poor description of a problem this is all i can give you.
(1,763 Views)
Here's a little pseudo code to think about...
  1. Initialize pinX as Input
  2. Count = 0
  3. Read pinX
  4. IF pinX = HIGH
    1. Then Count = Count +1
  5. Goto 3
=== Engineer Ambiguously ===
(1,754 Views)
I need to increment a value in 7 segment display when avoidance sensor detects a object and thus activate servo motor  and other avoidance to sensor decrement that value when "car" leave in car parking system.
(1,728 Views)
Hi titos,
@titos_sampas wrote:
I need to increment a value … when avoidance sensor detects a object and thus activate servo motor  and other avoidance to sensor decrement that value when "car" leave in car parking system.
Some pseudocode:
IF RisingEdge(AvoidanceSensor1) THEN
  value++
ENDIF
IF RisingEdge(AvoidanceSensor2) THEN
  value--
ENDIF
The 7 segment display is a different "problem": here you just need to convert your "value" into the corresponding DO signals to light up the correct LEDs…
(1,716 Views)
