Labview Image Processing
Algorithm given to me is like this.
Step 1: Capture image from a system
Step 2: Extract the region of interest.
Step 3: Select a row approximately in the middle of the membrane area.
Step 4: Determine the intensities at all the points across the membrane.
Step 5: Plot a graph of the intensities across the row (the line profile).
Step 6: Observe the minimum and maximum intensities along the row.
I need to construct the block diagram for this in labview. Please help me to do this.
I am alresdy extracted the image and roi. how to do the remaining things?
Message 11 of 21
(5,264 Views)
This is what I exacly want.
Message 12 of 21
(5,257 Views)
Are you the same user  aradhrockzz@gm…  or differnt user logging from same PC?
-Post the vi/snippet which you developed and stuck with.
-What you are extracting?(Membrane area?)
-If the ROI has the membrane area then from the ROI bounding box(left, Top, Right, Bottom) which is rectangle you can caluclaute the middle row line points.
- Did you check the line profile example http://www.ni.com/example/30560/en/ ?
- ROI Profile gives the statistcis you want as min, max in the ROI : https://zone.ni.com/reference/en-XX/help/370281M-01/imaqvision/imaq_roiprofile/
uday
Message 13 of 21
(5,255 Views)
Hope you have to try something by your own and get help in forum, else go through the examples/tutorials suggested by other users .
Its not good to expect a end solution based on your Flowchart, which wont help you to learn and even makes you lazySmiley Happy
Message 14 of 21
(5,248 Views)
aradhrockzz@gmail.com and arunamv12 are different users doing same work with some differences logging in same pc. ROI of the membrane area.
Message 15 of 21
(5,245 Views)
share us the code/snippet which you have tried, not the Image of front panel.
Message 16 of 21
(5,236 Views)
I am attaching my algorithm and my code. Plz check ..
Message 17 of 21
(5,218 Views)
Message 18 of 21
(5,215 Views)
That is not code at all. Just an image.
-You need to attach VI(.vi)
- Or LabVIEW snippet( how to create snippet http://www.ni.com/tutorial/9330/en/)
uday
Message 19 of 21
(5,206 Views)
Attaching vi
Message 20 of 21
(5,202 Views)
