Labview IP integration node problem
hi,
I have just started using integration node for some DSP code.while some of the vhdl programs work,some wont.
i m using IP node, with FPGA project  option" Reseries DAQ on mycmputer" i.e only simulation as no hardware is involved.
I am attaching the vhdl files for simple AND gate, MUX,demux, and corresponding labview project ,and vi's. AND gate dosn't work,while mux,demux do.
any help?
also, I have written VHDl code for convolution,using integer array as new data type. If i want to use the same vhdl file inside IP node, how do i do that? node only supports fixed point,boolean,and boolean array.
How would it support user created integer array?
Also, is is poosible to run vhdl code with functions/components in IP node in labview?
lastly, whats difference between CLIP node and IP node?
thnks
sid
Message 1 of 1
(3,106 Views)
