Labview HDL node (compiler help)
hi,
i hv following basic questions about labview hdl node
1)do we get the hdl node with labview fpga module only or is it a standalone control?
2)one can write his/her vhdl code in hdl node.but, same node can be used to import external vhdl code or some other labview control is used?
3)how does the vhdl node compile?does it compile with labview compiler,or is it the XIlinx compiler?wht my concern is that labview has mathscript node and matlab script node,so in mathscipt ,its the labview compiler which does it,while with matlab node,it gives flexibilty of compilation with matlab ,and debugging with the matlab editor.so, if the imported hdl code compiles in the standard fpga company compiler, it would be better as it would be more robust.
3)similarly, in labview fpga, can we simulate by calling multisim?
need a urgent reply
sid
Message 1 of 1
(3,150 Views)
