Labview Formula node
Hi, Have a good day.
I am having trouble with the formula addition step, does anyone have any ideas about my mistake here or how I can solve it in a different way?
I am collecting data as voltage but I want to obtain it as inches after the formula. (I am using an ultrasonic transducer)
The formula is going to be:
y = (0.0332x3 - 0.5023x2 + 22.425x + 17.538)*0.393
y is going to be inches value I want.
x is an voltage value measured as an voltage.
If you have any other questions , please let me know!
Thanks!
(2,284 Views)
I don't see a formula node.
Bill
CLD
(Mid-Level minion.)
(2,269 Views)
Sorry, I uploaded wrong picture.
This is the original block diagram.
I need to add that formula inside this block diagram, but not sure where and how to do that.
(2,265 Views)
I solved the problem.
Thank you !
(2,245 Views)
Thank you !
While you might have solve that particular problem, there are still more problems
  • Index array is resizable, no need to branch the array wire.
  • You can use "array to cluster" with size set to two to eliminate index array and bundle. (there are other possibilities)
  • You can set the VI execute option to "clear indicators when called". No need for these local variables. Make "No Error" the default value for the error string if you like ("clear" means "display default" here). See image below.
  • Your clearing of the chart occurs in parallel to the while loop and you cannot guarantee that it happens first. Just wire the error out of the property node to the loop edge to ensure correct execution order. LabVIEW is fully parallel and execution order is not determined by code placement, but only by data dependencies).
  • Your interval control has the wrong representation (I32 instead of U32)
  • When asking for help, we prefer actual VIs over pictures.
(2,226 Views)
Assuming it should be applied to all array values, here's how to do that:
(2,212 Views)
And if you move the multiplication before the polynomial evaluation, it will happen at edit time instead of run time.
(2,183 Views)
