Labview FPGA error -63044
I am trying to call a FPGA vi with a vi on the main project so that i can read from it and save the data that it acquires. The vi works but if it runs longer than 6 or so seconds i get the -63044 error code and I am not sure why. In the description of the error code it says to check NI max to make sure I have a certain software installed for the Crio and NI max and i do. If anyone could help shed some light on my problem it would be greatly appreciated.
(2,807 Views)
Do the shipping example(s) work?
Have you checked the Getting Started Guide of the hardware you are using?
ALE Consultants
(2,802 Views)
I havent looked at the shipping examples and it has been awhile since i looked at the getting started guide. I will go back and give it a look over.
(2,800 Views)
