Labview FPGA compile fails when an input to diagram disable is unconnected
When I have a diagram disable structure in my VI, the compiler fails with an error stating there is an unknown symbol UNDRIVEN_INPUT in a case object. Attaching a signal fixes the problem
(2,700 Views)
Hello...
          Why are using disable structure...? Is it really needed...? And which signal fixes the problem...? Can you please explain in some details.?
(2,615 Views)
