Labview FPGA compile error
I came up with a compile error, saying the following when I start the FPGA compilation
LabVIEW FPGA: The compile worker cannot perform the compilation. The compile worker may be configured incorrectly for this compilation or it may be in an error state.
LabVIEW FPGA: The compilation cannot be performed by the compile worker. The compile worker may be configured incorrectly for this compilation, or it may be in an error state.
Error -61330 occurred at niFpgaCompileWorker_ProcessStatusPipe.vi:1<-niFpgaCompileWorker_GetStatus.vi<-niFpgaCompile_Worker.vi:1
I am using LabVIEW FPGA, with a PCIe 7842r. I have tried to reinstall the Xilinx 13.4, but it didn't help.
Any comments and suggestions are highly appreciated!
Best,
Matt
(3,938 Views)
What OS are you running on? LabVIEW FPGA compilation tools are not supported and won't under Windows 10.
(3,890 Views)
Hello, i am using window 7 and it works fine a usual. Don't know what's wrong this time.
I have reinstalled labview and problem solved!
(3,868 Views)
Has it been determined why a reinstall would fix this issue?
I have same error on the same system (Windows 7). I'd prefer not to have to reinstall my entire LabVIEW setup if possible.
(3,772 Views)
I had a similar error, and a repair of LabVIEW and all of the Add-Ons resolved it for me. So if you're reluctant to do a reinstall, a repair may fix it for you.
(3,759 Views)
