Labview FPGA Error
Dear All,
I am facing a weird issue with my LabVIEW FPGA code.
I have a NI 9237 attached to cRIO 9035 and I have created a FIFO of 32767 elements and data type is fixed point. I combine all the 4 channel data and wire it to the fifo and everthing seems fine. But as soon as I save the vi it gives a broken arrow and the error redirects to the FIFO stating : "This node has experienced an unexpected error. Please redrop the node or contact National Instruments.
CLD Using LabVIEW since 2013
Message 1 of 11
(4,427 Views)
You might try pipelining the data through the loop, so you wire the data array into a shift register, and then feed the shift register into the FIFO.
I assume it's a target to host DMA FIFO? Does a smaller FIFO size have any effect on the error?
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
Message 2 of 11
(4,390 Views)
Thank you for replying,
I have tried pipeling but that doesn't seem to work.
Yes it is a Target to Host DMA and the fifo size does not make any difference and the error still persists.
Message 3 of 11
(4,369 Views)
Is this VI in a project and under an FPGA target?  This error is not very typical and what you are doing is quite straightforward.
ALE Consultants
Message 4 of 11
(4,364 Views)
I am using a cRIO 9035 and 4 NI-9237 cards. It is a FPGA project and the FPGA vi is under the FPGA and the RIO programming mode is set to LabVIEW FPGA interface.
Message 5 of 11
(4,351 Views)
Then I am not sure what else to recommend.  Unless you can post code so that others can try to see if it is the code or your configuration.
ALE Consultants
Message 6 of 11
(4,346 Views)
I made a quick project with your hardware configuration and FIFO, and didn't seem to have any issues saving. I've attached the code - see if you can open and save the FPGA VI.
Message 7 of 11
(4,341 Views)
Which Labview version you are using, I will upload a sample project.
Message 8 of 11
(4,338 Views)
Thank you MichaelBalzer for the code.
I beleive the problem is with my Labview because when I opened your labview project I am facing the same issue. May be I need to reinstall LabVIEW.labview error.PNG
Message 9 of 11
(4,337 Views)
It does look like an installation issue. You might try reinstalling the FPGA module first, or bite the bullet and reinstall everything.
I'm using LV 2017 at the moment.
Message 10 of 11
(4,334 Views)
