Labview FPGA 2012 - Clock Signal
I'm trying to access the FPGA clock signal in Labview 2012. I have a NI PCIe-7852R card, with which I'm using the 40MHz onboard clock signal. I'd like to use that signal to clock some logic in my design, but there seems to be no easy way to access it - or, at least, the "clock signal" component has its own data type which only connects to a timed loop (the logic in question is in the form of a VHDL black box, which requires multiple clock rates; therefore since the IP integration node only allows one signal to be tied to the clock I need others as well, which will be fractions of the onboard clock). Any advice?
Message 1 of 1
(2,435 Views)
