Labview Execution Failure
I am able to install, but unable to run Labview 6.0i. It will always crash with a "Failure window.cpp line 1239" error. I have tried all of the suggested fixes in the Knowledge Base regarding this type of failure to no avail. I have also tried to install the newest update, but am unable to.
I am running Windows 2000 SP-2 on an IBM Pentium 4 with an Nvidia Quadro2 Pro video card.
(2,987 Views)
This is most likely a video driver problem. Since you didn't specify anything you have tried here are a few suggestions.
1. Update video driver
2. Turn off/down video acceleration
3. Change resolution/number of colors
4. Try running it with the Standard VGA driver (This will show if it is a video driver or a problem with the install of LabVIEW).
Marcus Monroe
Application Engineer
(2,987 Views)
