Labview Evaluation for acadmic usage
can i use LabVIEW Evaluation for academic usage. i couldn't find clear answer.
Thanks.
(1,182 Views)
You can evaluate but to use it beyond evaluation you need the Academic license - https://www.ni.com/en/shop/academic-volume-license.html
Santhosh
Soliton Technologies
(1,173 Views)
Depending on what exactly you are doing with it academically, you may qualify for using the free Community edition.  Read details here:
https://www.ni.com/en/support/documentation/supplemental/20/labview-community-edition-usage-details....
Short version is that you should be OK under one of these cases:
  • For all primary and secondary schools (K-12), for anything
    • Or equivalent if you're not in USA, basically not University education
  • For clubs and competitions (such as FIRST Robotics) outside of K-12 education
    • Meaning you can use it at a College/University setting if it's not being used in a classroom, not required to use as part of a course, and not for profit
  • If you are a student using it outside of class for personal use unrelated to classes
(1,138 Views)
thank all for replying.
In one course module in master (not the thesis) i could solve the homework with any other programming language like python, but i have decided to use LabView.
my use:
solve the homework in labview and write the results in report. Is it possible to use evaluation?
(1,100 Views)
