Labview Embedded module for blackfin processor
hi
i want ot know that, Labview Embedded module for blackfin processor full development kit is essentail for detecting Blackfin Board.
I have all the software to detect the board but only Labview Embedded module for blackfin processor is Evaluation version.
so is that a resion for not detecting the Board
Regards
mithun patil
Message 1 of 8
(5,320 Views)
Hi Mithun,
Make sure that you have Visual DSP++ 4.0 for LabVIEW Embedded installed as well.
Michael P
Message 2 of 8
(5,302 Views)
Dear Sir ,
I have installed Visual DSP++ Version 4.
I have Labview 7.1 as well as labview 8 with me.
I have installed Labview 7.1 Embedded module for blackfin processor [Evaluation Version]
I am able to detedt the card through visual DSP++.
but not through.
I want to Know Embedded module for blackfin processor [Evaluation Version] is the resion for not detecting the card.
I am not able to see target as ADSP-537 Black fin processor.
Regards
mithun
Message 3 of 8
(5,294 Views)
Just to be clear: The version of VisualDSP++ you need is not just VisualDSP++4.0, but VisualDSP++ 4.0 for LabVIEW Embedded. It is a special version created especially for use with LabVIEW Embedded. Go to the Help>About window in VDSP and verify that this is the product name. The evaluation version should not matter as long as the evaluation period has not expired.
Message Edited by Michael P on 08-07-2006 11:26 PM
Michael P
Message 4 of 8
(5,294 Views)
Yes i am sure that i have Visual DSP++ for Labview Embedded activated for 90 days
Then also I am not able to detect the board,
i want to confirm that after opening Labview Embedded 7.1 , is ther anything required to configure target or create embedded target from tools options of Embedded labview .
Regards
mithun
Message 5 of 8
(5,278 Views)
Mithun,
You also need to have the LabVIEW Embedded Signed Module activated on your machine.
Michael P
Message 6 of 8
(5,261 Views)
hi
What is this LabVIEW Embedded Signed Module,
Where i will get that,
how i can activate that, and wheather it is available with Evaluation module.
Regards
mithun
Message 7 of 8
(5,253 Views)
To activate, go to ni.com/activate and select LabVIEW, LabVIEW Embedded Signed Module, 7.1, then click GO. On the following screen, enter your computer ID/serial number/email to receive an activation code.
Since you said you have the evaluation, you probably don't have a serial number. Open the NI License Manager (Start>>Program Files>>National Instruments) and select LabVIEW Embedded Module to see if your evaluation has expired.
Message Edited by Michael P on 08-14-2006 09:29 AM
Michael P
Message 8 of 8
(5,225 Views)
