Labview Driver for Garmin Nuvi 255W
Does anyone know how to write a Labview driver to talk with a Garmin Nuvi 255W via USB?  Any feedback would be greatly apprecitated.
(3,557 Views)
I did a quick search and found information for communicating over USB with examples in other programming languages:
http://www8.garmin.com/support/commProtocol.html
Jim
(3,539 Views)
Thanks for the feedback.  I have some Labview code that talks over RS-232 to an old Garmin GPS 2 plus.  How hard would it be to replace the serial interface with USB?
(3,529 Views)
It would be very hard since the two protocols are completely different. Unless the device shows up as a virtual COM port. This would require that the manufacturer used a chip that would make their device appear as a serial port to the computer. Do you know if they did this?
The Garmin SDK that was linked to probably has a DLL that you can call from LabVIEW. You should try to check it out and see. In this case you'd be asking the same question as this one: http://forums.ni.com/t5/LabVIEW/usb-to-usb-driver/td-p/1209209.
(3,513 Views)
