Labview DSC 2015 With Labview 2015 64 Bits
Hello everyone,
I like to know if it possible to install the labview DSC 2015 module with Labview 2015 64 bits. When i run setup, a message appears telling me to install Labview before install the DSC Module. Maybe i must install a 32 bits version of Labview??? If someone has a idea...
Thanks for all,
Alex,
(6,239 Views)
Accepted by topic author Alexandre90000
From the LabVIEW Readme:
Supported Modules
LabVIEW 2015 (64-bit) supports only the NI Vision Development Module. Refer to the Vision Development Module documentation for more information. No additional modules support LabVIEW 2015 (64-bit).
Sounds like you will need to run LabVIEW 32-bit.
(6,231 Views)
I also meet the some problem , My  system is Win7 64 bits,
My  labview  version is  2015 64 bits,
Do you know how to solve this problem ,
Thank you
(4,948 Views)
Like Bob Schor answered two years ago, you'll need to install a 32-bit version of LabVIEW, if you have the same problem.
This will work fine even though you have a 64-bit version of Windows.
To expand given the change in date, even if you install LabVIEW 2016, it still won't be usable in 64 bit. From this link (http://www.ni.com/pdf/manuals/374715g.html#lv64bit), it doesn't look like it will change in the 2017 version either.
GCentral
(4,945 Views)
