Labview, DAQ Cards and Drivers
How do you tell if Labview, DAQ Cards and Drivers are compatible w one another?  In other words if I developed in Labview 5 ( exaggerated of course) and create an exe can I use it with a PXI-6229 and its drivers bought in 2017 ??  Are there 3 different spec sheets?
Thanks..
(3,322 Views)
Accepted by topic author Clint1000
Hi Clint,
there are compatibility charts for LabVIEW vs. DAQmx. And with each DAQmx version there is a document describing which hardware is supported…
In case of trouble: phone the NI support!
And when upgrading from LV5 you surely want to change from TraditionalDAQ to DAQmx…
(3,305 Views)
Thanks ..perfect.
(3,280 Views)
