Labview Crashes
@Martin_Kroner wrote:
I am to slow, sorry..
I did not compile any of my code. It runs in the "development mode" of labview.
I did indeed also change the computer, but this was maybe 6 months before the code became unstable.
Ahhh, a basic misinderstanding.  VIs are actually compiled code.*  Pretty weird if you come from a text-based language background.  What Norbert wants you to do is select "Mass Compile" from the Tools --> Advanced menu and mass-compile your project.  🙂
*This is why sometimes if you modify a subVI you have to save the VI that calls it.  it is because it needed to recompile.
Bill
CLD
(Mid-Level minion.)
Message 11 of 24
(2,188 Views)
OK. I will try this and come back to you.
Martin
Message 12 of 24
(2,184 Views)
OK, I did it.
There are some warnings but onyl about libraries and VIs provided by by companies to interact with a  their devcies. But non of the vis I wrote myself created an error or warning.
Message 13 of 24
(2,179 Views)
OK, I did it.
That's good!  That means they just recompiled without complaint.  Hopefully this helps - be sure to let us know.  🙂
Bill
CLD
(Mid-Level minion.)
Message 14 of 24
(2,168 Views)
Labview crashed again after my code was running for ~24h. The mass compile apparently did not fix the problem. I am wondering, the error message from the crash log file "Thread consumption suspected" what does this actually mean?  Maybe I can fix this issue by avoiding certain features of Labview that are unstable in my environment?
Thanks for the help!
Martin
Message 15 of 24
(2,134 Views)
I have to admit that I am out of ideas.  😞
Bill
CLD
(Mid-Level minion.)
Message 16 of 24
(2,125 Views)
If your LabVIEW license comes with LabVIEW Desktop Execution Trace Toolkit, you may check it out. It helped me in many cases to troubleshoot errors. I think it is included in the professional LabVIEW package
Message 17 of 24
(2,113 Views)
Is there a particular reason for using 64 bit s instead of 32 bits.
Perhaps you have a very good reason to go 64 bit
Pictures being processed or high rates of data acquisition or large graphical displays..
There Is a 32 bit version of LabVIEW 2013 out there.
If nothing else works for you
I would give the same code a shot in 32 bit mode if at all possible.
To do this however (i Think) complete uninstall of the 64 bit LV is necessary but I am not sure. Others can correct me if I am wrong.
Message 18 of 24
(2,108 Views)
PS
Please don't do anything until you hear more input.
My idea is not a guarantee to fix your issue. I am not total expert in all LV things as seen by my not posting too often.
Message 19 of 24
(2,104 Views)
32-bit and 64-bit can live peacefully alongside each other.  Also, your source code opens up fine in either one.
Bill
CLD
(Mid-Level minion.)
Message 20 of 24
(2,097 Views)
