Labview Crashes when adding case and sequence structures
> I am running into a problem that I have never experienced before -
> when I am adding case and sequence structures to a version of code I
> am writing, Labview 6i crashes (i.e CPU allocation jumps to 95% on the
> task manager and hangs there) requiring an "end task". I am writing
> the code within XP Pro running on a 1.7 Ghz Pentium 4 machine with 512
> MB.
It sounds to me like you have a very large VI and are continuing to add
to it. You would be better off moving some of the code into subVIs.
Fro the description, I can't tell what sort of editor limit you are
hitting. Please submit the VI to tech support so that this can be
investigated further.
Greg McKaskle
Message 11 of 11
(363 Views)
