Labview Compatibility
Software compatibility problem between the interface card drivers and the LabView 5.1 software. The computer appears to crash and the Windows blue screen of death appears.
(3,527 Views)
What software versions, OS version, interface card driver name,
manufacturer, etc, etc?
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,527 Views)
So I assume you are not running LabVIEW on a Mac?
(3,527 Views)
That is correct, I'm running on Windows XP, the problem is that the drivers which are supposed to be compatible with Windows XP will not work with LabView 5.1
(3,527 Views)
Doesn't LabVIEW 5.1 predate Windows XP?
Any reason that you can't upgrade?
Les Hammer
(3,527 Views)
Hi Rob,
If possible, I would definitely suggest upgrading versions of LabVIEW (latest version is 7.1 for Windows) as this would be the most immediate and easiest solution.
In referring to the LabVIEW 5 User Manual, LabVIEW 5 is officially supported on Windows 95 and NT. Since Windows XP did come out after LabVIEW 5.x, LabVIEW 5.x was most likely not tested in XP.
What kind of interface cards are you using? Are you communicating to any hardware using LabVIEW?
Kileen C.
NI
(3,527 Views)
