Labview Code or stepper Problem
Hi guys.
Ive cretaed a VI to control this stepper motor but im getting erratic movement of the rotor but before i troubleshoot the program i decided to open up the motor and found the motor coils to be touching and not correctly wound. I know this is probably the wrong place to post this but i would like to confirm that the stepper is a dud before i continue to troubleshoot my code. Can anyone confrim that this stepper is indeed incorrectly wound??.
(2,573 Views)
A better scaling of the picture size would have been nice....
However, I have seen worse working, and the wires are coated 😉 . Did you measure the resistance between the connectors(and to the housing)?
So let us have a look at your wires... in the diagram and how you connected the motor to the driver. Links to the motor and driver spec are also a good idea.
Greetings from Germany
Henrik
LV since v3.1
(2,565 Views)
