Labview Code Module used in NI TestStand: Memory leakage
hello, I have the following problem and cannot find a workaround:
  • In testStand I call a SubSequence as new execution, by passing an array [0..7] of Waveforms (Labview Analog Waveform Type) as reference.
  • Within the called Subsequence I call a LabVIEW Code Module for reversing each passed Waveform (each array[0..7] element) using the "Reverse  1D Array". (see attached screenshots with Block Diagram and Parameters as used in the testStand code module step).
  • The VI execution mode is set to “Shared Clone Reentrant” since I need to use it in 5 parallel testStand Executions.
  • The VI input and output parameters refer to the same TS Sequence Parameter (but I think it is normal since I need to reverse in place the same array). See the attached picture as reference.
  • The labview code module works fine (it does what I expect) but…I experience a MEMORY LEAKAGE after a while.
Is anybody able to help me?
thank you in advance!
Giovanni
Certified TestStand Developer
(2,371 Views)
You might have better luck with "Preallocated" because LabVIEW will preallocate one clone for each instance, while "Shared" creates them dynamically - on the fly - as needed.
To be clear, I'm not sure if this will make a difference.
Bill
CLD
(Mid-Level minion.)
(2,338 Views)
