Labview Bug?!?
Think I may have found a bug. Comments please. Follow this link for
the code:
http://yourpage.blazenet.net/ninnurta/labviewbug3.vi
This link refers to a vi that was written with Labview 6.0.2, but I
have seen the same behavior in 5.1. Is this normal functioning?? I
have a program that has this same basic structure, although I am not
using empty array constants to control the inner loops. I do have
instances where loop control arrays are empty, though and saw the
behavior in this instance.
greenman
(2,861 Views)
This is not a bug. Non-indexing outputs of a loop that do not execute are
undefined. Execute the VI in debugging mode and you will see that the wire
exiting For Loop 2 has no data source and then returns any garbage left
there by previous memory usage. You fix this outputting the value in a shift
register properly initialyzed.
See attached fix.
Jean-Pierre Drolet
Scientech R&D
"greenman" a écrit dans le message news:
1a51ebaa.0106221216.2afb8bf0@posting.google.com...
> the code:
mal functioning?? I
> greenman
[Attachment nolabviewbug3.vi, see below]
LabVIEW, C'est LabVIEW
(2,861 Views)
