Labview Basics
Hello.
I'm new to labview.. I'm trying to reset the first call based on the this:
http://forums.ni.com/ni/board/crawl_message?board.id=7124&message.id=991
please..  I'd like to ask what the simple that connected to the loop condition ?? ,
many thanks in advance
Message 1 of 13
(5,928 Views)
That is a boolean constant.  (Newer versions of LabVIEW simplifed that to just show the True, or the False, not the fact that you can swap between them.)  In this case it is set for False.  It is also much more common nowadays for 1 run loops to have a True wired to a Stop condition terminal rather than a False wired to a Continue terminal.
Message 2 of 13
(5,922 Views)
That's a False constant.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 13
(5,921 Views)
Thank you so much ..
I treid to change it to false constant but it would do the job.. since it still first_time (the output is on even after first loop)
regards
Message 4 of 13
(5,915 Views)
What's the purpose of the loop at all?
Did you debug your VI? What's the input value?
Message 5 of 13
(5,910 Views)
The first time you read it after a Reset you want FirstTime to be true. 🙂
/Y
Qestit Systems
Message 6 of 13
(5,906 Views)
Hi..
It is to be used to initialize the initial conditions for sub vi .. only for first call
regards
Message 7 of 13
(5,904 Views)
Hi Benomair,
So when you want to initialize ONLY for first call you don't need all those additional stuff.
When you want to initialize based on a different condition you don't need the FirstCall? primitive…
Message 8 of 13
(5,890 Views)
Hi GerdW
thanks ..
sorry it might be too simple (I'm new to Labview) .. but I don't know how to initialize the initial condition for sub vi that using formula node ..
in Matlab I used this code to do so
persistent X_hat;
if isempty(X_hat)
X_hat=[0.018 0 0.894]';
end
regards
Message 9 of 13
(5,876 Views)
Perhaps you should show up your subVI and its caller so we have a better idea of what you are trying to accomplish.  We can offer better help then.
Message 10 of 13
(5,866 Views)
