Labview Arduino Serial Communication
Hi Everyone,
                    I am trying to get arduino to receive a message from labview and then run a function within arduino from this message. I am using the serial event architecture. Arduino function beginFunction() successfully sends a message to labview, but labview does not seem to send a message back. My arduino code is as follows:
void loop()
if(start==true)
beginFunction();
if(inputString.equals("move"))
moveUntilPos();
if(inputString.equals("scan"))
scan();
void serialEvent()
while (Serial.available())
char inChar = (char)Serial.read();
if (inChar != '\n') {
inputString += inChar;
if (inChar == '\n') {
stringComplete = true;
my labview file is attached.
It does not seem to register the message in arduino, does anyone know why?
Sam.
(4,261 Views)
my vi does not send serial messages, can anyone see why? The serial write vi is in the consumer loop
thanks
(4,186 Views)
1. Go look at the advice I already gave you again (https://forums.ni.com/t5/LabVIEW/Indicators-change-too-fast/m-p/3674363#M1032820).  You should especially look at the example I gave you.
2. No need to initialize the same port twice.
3. You need to tell the VISA Read to read MORE bytes than your message.  I like to use 50.
4. Why do you have a 5 second wait in your write loop before sending a response?
5. For where you are sending the message, change your message to be in '\ Codes' mode.  You are not sending the Line Feed (0xA, \n).  You are actually sending a '\' and an 'n'.  When you switch to '\ Codes', then you will see "\\n".  "\\" is the code for a single '\'.
(4,169 Views)
