Labview 8 executables: Random toggling through controls
Using Labview 8 pro I found that you can toggle through the controls with the tab key. However, the sequence of the toggling appears to be random.
Does anybody know how to get that toggling into a certain sequence, i.e. setting the cursor with the mouse on the first control and then by pressing TAB getting the cursor jump to another, specified control?
Thanks a lot.
Holger
(3,075 Views)
Hi, Holger,
Edit->Set Tabbing Order may be helpful for you.
best regards
(3,069 Views)
Hi Andrey,
thanks for the quick reply. I am not cocerned with tab controls.
I just have some numeric controls on the front panel. When I build an executable and run it, I can toggle through these controls by means of the TABkey of the keyboard. The sequence of this toggling procedure appears random to me. I would like to set it to a particular sequence. Any idea?
Thanks a lot
Holger
(3,064 Views)
Hi Holger,
just do it like written in post #2. 'Setting tabbing order' does what you asked for and has nothing to do with tab controls.
The tabbing order is not random, it's the order of placing controls on the frontpanel while programming!
(3,061 Views)
Thanks a lot. It works now.
Holger
(3,056 Views)
