Labview 8.6 Crashes while importing SO
I have a Shared library that I built using the following and when I try to import it using the Import Shared Library wizard Lab view crashes.
[code]
        g++ -fPIC -shared -Wl,-soname,libCAPI.so -o libCAPI.so ${APIOBJECTS} ${DETAILOBJECTS} ${OBJECTS} -L../..
/../utl/Common/XML/ -L../../../utl/Common/Exceptions ${COTS_ECLIPSE_BOOST_LIBDIR_38}/libboost_thread-gcc41
-mt-1_38.a ${COTS_ECLIPSE_BOOST_LIBDIR_38}/libboost_filesystem-gcc41-mt-1_38.a ${COTS_ECLIPSE_BOOST_LIBDIR_38}/libboost_
system-gcc41-mt-1_38.a ${COTS_ECLIPSE_BOOST_LIBDIR_38}/libboost_regex-gcc41-mt-1_38.a ${COTS_ECLIPSE_BOOST_LIBDIR_38}/li
bboost_date_time-gcc41-mt-1_38.a ../../egse_api/libEGSEAPI.a -lXML -lExceptions -lc
[/code]
I'm using Labview 8.6 and when the crash occurs I get the following error:
[code]
LabVIEW caught fatal signal
8.6 - Received SIGSEGV
Reason: address not mapped to object
Attempt to reference address: 0x98
Segmentation fault
 [/code]
 I can create a shared library with a very simple so of the following:
[code]
#MakeFile
libTest.so : test.o
    @echo Building Library
    gcc -shared -Wl,-soname,libTest.so -o libTest.so test.o -lc
test.o : test.c
    @echo Building ABC
    gcc -fPIC -g -c test.c -o test.o
//from test.h
int sum(int i, int s);
//from test.c
   return i+s;
[code]
(2,637 Views)
Hello Michael,
What operating system are you calling you library on? Also is there a .cpp error that occurs when restarting LV? Is there a dump file that you could provide?
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(2,619 Views)
