Labview 8.5 installer build *.exe wrong date code
In Labview 8.5 application installer build *.exe has a date code of 7/17/2007 even though it was built today.  It will not update even after deleting it.  Is this a known bug?  SS
(2,858 Views)
Hi SS,
The Date Modified property of setup.exe shows the date the MetaInstaller was built.  This was true in earlier versions of LabVIEW as well.  It was reported to R&D (# 3T87DAP4) but was determined to be expected behavior.  The actual date and time the installer was built can be determined by looking at the properties of \bin\dp\install.msi.  Feedback is always appreciated, so please feel free to create a product suggestion if you think this should be changed.
Jennifer R.
(2,834 Views)
