‎03-12-2008 11:01 AM
MONTIX wrote:
Hey check your configuration for your workstation,it may not be able to process that much calculations.
‎03-12-2008 11:08 AM
‎03-12-2008 12:29 PM
You mean it still crashes? 😮
Can you post the code? Use the browse button below "Attachment" under the message edit box to browse and select the vi.
‎03-13-2008 04:21 PM
I found the problem. I had a wrong definition of probe at C:\Documents and Settings\Gabi\My Documents\LabVIEW Data\Probes
I delete all the probes in the above path and the problem was solved.
‎03-13-2008 08:37 PM
Glad to read you found the problem and thanks for sharing! 🙂
It's quite interesting that these behaviors could be anything.. That's why it's best not to re-install LV right away. Finding the root cause may help avoid headaches in the future. I must admit that I would not have thought of custom probes.. 🙂
