Labview 8.20 application builder
The EXE file I created with LabView 8.20 application builder immediately runs when loaded. I had unchecked the 'run when opened' check box in the source file settings prior to the build.  Is there some other setting that needs to be changed. Please advise.
Cheers
Herbie
(3,137 Views)
This is a known issue with 8.20 and NI is aware of it. See
http://forums.ni.com/ni/board/message?board.id=170&message.id=206415
(3,122 Views)
Hi!
And there is a workaround to solve it now! 😃
Check "Enable debugging" and "Wait for debugger on launch", in the Advanced Page of the builder, and you'll have the same effect.
Tania Lozoya
(3,110 Views)
Thanks for the information. I wiil try an alternative method
Herbie
(3,059 Views)
