Labview 8.2 and Digital Waveform Graph
Hi everyone.
I'm trying  Labview 8.2 with Digital Waveform Graph. In the attachment you can view my problem: when I add or subtract a signal this occur on the top of the graph and not on the bottom. The YScale.Flipped property is always FALSE, also if I wire a TRUE constant, like in my example.
Any suggestion about this problem ?
Thanks and regards.
(2,762 Views)
HI,
Maybe, I don't understand which is your problem.
the YScale.Flipped property If TRUE, reverses the positions of the minimum and maximum values on the scale, but doesn't change the position of the single signal. when you add or subtract a signal this occur on the top of the graph and not on the bottom because on the top of the graph there are the last signal.
Giuseppe Nardelli
(2,734 Views)
