Labview 8.0 driver CD
I can't find the Labview 8.0 driver CD in ftp.ni.com. I need that to solve the I/O assistant problem in my student version of Labview 8.0. I use I/O assistant to communicate with a NI ENET/100 GPIB card. Can someone repost the newest version of driver CD into the ftp zone?  I've followed some threads by Chris_R but didn't find the driver CD file he described in the ftp location.
(3,255 Views)
I think the intent is that you just download and install the drivers you actually need rather than clogging the network with a big download of which you might use 5% of the files in it. In your case, the latest GPIB drivers can be acquired from here. In general you look for the current drivers here and older ones here. It's always worked for me to do it this way.
(3,247 Views)
Thank you for the help! Actually my GPIB driver of the ENET/100 works fine. But the I/O assistant of Labview itself doesn't work right. It always claims that the I/O assistant wasn't installed correctly. I've tried to reinstalled the Visa and the Instrument I/O assistant Version 1.0.1 which doesn't work for me. Therefore I turn to the new driver CD which contains I/O assistant version 2.0.
(3,231 Views)
