Labview 7 crashes when opening an earlier Labview version VI
Hello guys. I am using Labview 7 professional edition. The labview crashes when opening an earlier labview version VI. The error message I'm getting is just "Labview has encounted a problem and eneds to close. We are sorry for the inconvenience." The VI contains a few Tag SubVIs, and It is written with an earlier version of Labview(BridgeView is what it was called).
Do anyone have any ideas that how I can fix this bug? It's going to be a great help. Thank you very much.
(2,446 Views)
LabVIEW should not be crashing in this situation. Now, does this happen for other similar VIs too? It could be possible that a particular VI is corrupt. Also could you post your VI here so that I can try and reproduce the problem at my end.
Chetan K
Application Engineering
(2,429 Views)
