Labview 7.1.1 Errors
I am using the version 7.1.1 of LV and LV RT, i am programming a cFP-2020.
Labview keeps crashing and losing the connection with the remote target (cFP), i am attaching a file containing all the error logs generated by LV, i never got this problem with earlier versions of LV i think this may be some kind of bug plase let me know how can i fix it.
By the way my PC is a PIV @3 GHZ , 1 GB of RAM running WinXP SP2
(2,623 Views)
Are you connected over a hub or a switch or directly, I had problems devloping apps on a busy network similar to those you mention.
I changed the config for a switch and created my own segment then changed the MAX settings for the network timeouts, that seemed to do the trick nicely for me.
(2,619 Views)
